A connection has been discovered between 2 VPEX cascaded daisy chains. However, the specified slot does not support ring topology operation in this version of EXOS.
Check whether ring topology is supported on this slot type in a subsequent version of EXOS and consider upgrading if so.
Warning
Slot %slot% does not support ring topology in this version of EXOS which is preventing ring detection between ports %port1% and %port2%
| Name | Type |
| slot | Slot |
| port1 | SlotPort |
| port2 | SlotPort |
